Hi,
I’d really enjoy if I could put some sort of geo based filter on the data plans.
Fx, when I’m in my home country, I have a soft limit of 4 GB data. When outside my home country, and within EU, I have a hard limit of 5 GB.
And when travelling further, I often buy data Sims as well. Would be nice if the data plans could “automatically” handle this somehow.
@PeaceDealer
Thanks for your feedback. Do you think this could be accomplished some way besides asking the GlassWire user for his location? Sounds kind of scary…
Alternatively, some sort of quick enable / disable for plans, like whether data should or should not count against a plan.
Or even, if it could just be set up as a home / roaming plan. Maybe you can query the phone data if its in roaming mode.
