Glassire Basic Not Loading On Startup?
Hi all. I just updated to the latest build (3.9.1102), and it no longer loads on startup. In Settings > General, Run on startup is selected.
Can anyone help?
Hi
Options to do…
Open task manager and look in Startup apps and see it it is Enabled
You could uninstall and re-install, then reboot.
Another option is the create a shortcut in the path below, with your user name.
C:\Users\Your-user-name\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
See how you go with these options…
