GlassWire 2.0.84 is now available.
https://www.glasswire.com/download/
What’s new?
Fixed a bug that caused our “Ask to connect” mode to work incorrectly for some users.
Fixed a bug that caused some users to crash when dragging GlassWire between two monitors.
Made changes to GlassWire to avoid false positives from Windows Defender.
Improved the upgrade process from GlassWire 1.X to GlassWire 2.X.
Solved a problem where some GlassWire users could not switch on the GlassWire firewall setting.
Updated the “Usage” tab so it fixes a problem that caused some GlassWire users to see incorrect usage stats.
Many other fixes and improvements.
Thanks for helping us find these problems so we could fix them and we hope you’ll upgrade to 2.0.84 soon!
