GLASSWIRE and WATCHDOG VIOLATION
Hi,
Glasswire driver (gwdrv) create a BSOD with this error message DPC_WATCHDOG_VIOLATION.
Here the message from WhoCrashed :slight_smile:
On Tue 24/07/2018 11:59:22 your computer crashed or a problem was reported
crash dump file: C:\WINDOWS\MEMORY.DMP
This was probably caused by the following module: gwdrv.sys (gwdrv+0x424e)
Bugcheck code: 0x133 (0x0, 0x501, 0x500, 0xFFFFF8030B279378)
Error: DPC_WATCHDOG_VIOLATION
file path: C:\WINDOWS\system32\drivers\gwdrv.sys
product: GlassWire
company: SecureMix LLC
description: GlassWire Driver
Bug check description: The DPC watchdog detected a prolonged run time at an IRQL of DISPATCH_LEVEL or above. This could be caused by either a non-responding driver or non-responding hardware. This bug check can also occur because of overheated CPUs (thermal issue).
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: gwdrv.sys (GlassWire Driver, SecureMix LLC).
Google query: gwdrv.sys SecureMix LLC DPC_WATCHDOG_VIOLATION
I am on Windows 10, which is fully updated, all my drivers are completely updated to, and also, no thermal issu (never above 50°)
Thanks for your support.
Regards
@fdecourt
If you go to the top left GlassWire menu and choose ā€œAboutā€ what version does it show? Thanks.
Hi,
I have version 2.0.123
Did you get a .dmp file on your desktop after you crashed @fdecourt? If not it’s probably not GlassWire that caused the problem.
If you do have a .dmp please email it to https://www.glasswire.com/contact/ using a cloud service like Dropbox, etc…
Not sure if I should bring up a dead post or start a new one, but I’ve had this similar issue recently with the newer builds of glasswire. I would get BSODs with DPC_WATCHDOG_VIOLATION on my surface pro 5.
The dump shows very similar to above, gwdrv.sys causing the issue. I love glasswire, but after numerous BSODs at random points (after hibernation, just working, after a fresh start, etc). i uninstalled it and have gone about 5 days so far without the DPC BSOD (or any BSOD). after usual usage.
Not sure if others are having this issue still, but I had to uninstall for my sanity. I hope maybe there is a cause or fix to get this working again.
@unreal
We very recently released an update of GlassWire. If you go to our top left menu and choose ā€œAboutā€ what version do you have?
Also, the most common reason for crashes lately is database corruptions (which is unusual) and the fix is to uninstall GlassWire, reboot, and do a ā€œclean installā€ option with our installer.
Also for anyone else, if you use Wacom be sure you’re using your latest Wacom drivers. We had another customer with a similar issue and he found it was related to an older Wacom driver, but this won’t apply to everyone of course. I just wanted to post it just in case it’s helpful to someone else reading this.
Well, I could try it again. I had whatever release was in the past 3 weeks. This was a replacement Surface which I’ve had since May 21, 2019. So it was a fresh DB as of then.
Regarding Wacom, that’s interesting. But I don’t believe the Surface uses those drives. I think it has its own pen drivers. everything is up to date though.
I’ll try the newest version and a fresh install again and see how it goes!
@unreal
Please email us the .dmp using a cloud service like Google Drive https://www.glasswire.com/contact/ and we can make suggestions, before you do a clean install.
If you don’t care about your history or settings though, it can’t hurt to do a clean install.
I guess windows deletes dmp files after a while. They seem to be gone. I’ll try fresh and if I get another, I’ll send it on by. Thank you!
@unreal
If GlassWire crashed then it will drop the .dmp to your desktop.
I got the same thing today (BlueScreen which caused my PC to reboot), with version 2.2.210 of GlassWire. I guess the problem is not fixed.
Here’s the crash analysis, according to WhoCrashed:
On Tue 21/07/2020 08:46:23 your computer crashed or a problem was reported
Bugcheck code: 0x133 (0x0, 0x501, 0x500, 0xFFFFF8064DAFA318)
product: GlassWire
I’ve uploaded the memory dump to my OneDrive and emailed the link to you. Please let me know your findings.
@harkonnen
We will look for the files, thank you.
Well, I was assured by email that the fix for the DPC_WATCHDOG_VIOLATION Blue Screen of Death would be in the next release. Now that the release notes are available for the new version, v2.2.241, I see that there’s no explicit mention of it whatsoever. So, has it been fixed or not?
I took the time to report it and send you the large memory dump – the least you can do is properly communicate whether it has been fixed. (I trust that you won’t try to say that the fix for a BSOD is considered so minor it is part of the ā€˜Miscellaneous bug fixes’ part of the changelog, and that you consider that to be adequate communication).
That is a generic crash name. We received many .dmp files thanks to helpful people like yourself and I believe it should be solved for you. However all machines and OS/Software combinations are different and it’s not yet possible to make perfect software.
Not sure what this has got to do with the point I’ve just raised. Again: why is there no mention of the fix in your release notes?
@harkonnen
I wrote the release notes myself. ā€œMiscellaneous bug fixes and resource usage improvements.ā€
I’m sorry the change list is not to your satisfaction. If you check previous change lists you’ll see they are about the same degree of detail.
The latest update had several hundred tickets so I don’t always list every single small fix we made. Also, we’ll sometimes introduce new features that have their own bugs and I’m not sure it’s useful to show fixes there.
Thanks for your feedback. We’ll consider adding more detailed change lists in the future.
Well, after what seems like a year since I last posted, I hope it’s fixed. I’ll be giving it a whirl. I truly miss Glasswire for its utility, but that BSOD was deadly for my workflow. Thanks for finally (hopefully!) squishing it!
Hi,
Just to add to this thread - i had exactly this issue, WinDbg pointed to gwdrv.sys as the issue however i found that the actual cause was a slightly out of date version of the Veeam Agent for Microsoft Windows that triggered the DPC_WATCHDOG_VIOLATION when it attempted to do a backup.
I found it by chance when i investigated the crash and noticed that the agent hadn’t backed up the laptop it was installed on in a while, so i started it manually, and boom DPC_WATCHDOG_VIOLATION.
I updated to the latest version, ran a manual backup and it went through no issue.
So as has been mentioned, it may not be Glasswire that is the root cause of the issue.
Thanks @TheBR.
Often when checking .dmp files with these types of crashes we’ll find it’s due to a third party software issue outside our control.
Updating all your software is always a great idea if anyone runs into this type of issue. Thanks for posting about your experience and I’m glad GlassWire is working for you now.
Hi, I reup this thread, because it is happening again :
Glaswwire Version : 2.2.304
It is happening when I am using PowerBi Desktop from Microsoft, latest version. To be able to use PowerBI, I have to uninstall Glasswire, which is not very convenient ! The same thing happen on two different computer, always when using PowerBI.
Crash dump directories:
XX\Windows
XX\Windows\Minidump
On Wed 26/05/2021 14:02:32 your computer crashed or a problem was reported
crash dump file: XX\Windows\Minidump\052621-10156-01.dmp
This was probably caused by the following module: [ntoskrnl.exe]
Bugcheck code: 0x133 (0x0, 0x501, 0x500, 0xFFFFF806344FA320)
Error: [DPC_WATCHDOG_VIOLATION]
file path: XX\Windows\system32\ntoskrnl.exe
product: [MicrosoftĀ® WindowsĀ® Operating System]
company: [Microsoft Corporation]
description: NT Kernel & System
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
crash dump file: XX\Windows\MEMORY.DMP
file path: XXWindows\system32\drivers\gwdrv.sys
product: [GlassWire]
company: [SecureMix LLC])
Google query: [gwdrv.sys SecureMix LLC DPC_WATCHDOG_VIOLATION]
Thanks
