glasswire is closing by itself every few minutes
Hi @thaiv
Sorry to hear about your issue.
Could you try updating GW & clearing GW cache? To clear GW cache, go to the menu at the top left corner, select “Settings,” navigate to the “Server” tab, click on the “Clear” button next to the “Clear GlassWire history” option, and restart the application. If those options don’t work, try running GlassWire as Administrator & checking for system errors. To check for system errors, run a disk check and scan your system for any errors or corruption. You can use the built-in Windows tools such as chkdsk and sfc /scannow to perform these checks.
Let us know if those solutions work.
Katie
