Glasswire tries to connect to the remote server but then stops after 3 attempts, if i shut it down again and restart it manually it will log to the local server . It will never start at log on. I have tried to completely uninstall even deleting the folder and all refs to Glasswire but with a new download the problem is still the same
This may sound kind of dumb, but can you uninstall, reboot, then reinstall and choose the “clean” option? The main difference is making sure to reboot and see if that helps.
If it doesn’t please email our helpdesk “help” email.
