Glasswire notification data plan based per connection
#1
It’s not really properly acknowledging usage per connection, might as well turn the feature off for now.
also suggesting if wiping the existing usage with a fresh start but have history tracking of the previous usage if that’s possible… thanks
#2
Thanks for your feedback. Is this feedback for Android or Windows?
#3
hopefully both, since I have an data plan LTE device connecting to my Windows desktop thru wifi which the results get affected with another connection that has unlimited bandwidth, so results would become inaccurate…
For android also yes if possible it could separate its own LTE connection with hotspot enabled and wifi connections it may have accessed.
