Hi, sometimes im clicking on the icon in the notification area and the app opens but way bigger than it should be, i cant see the top/sides/bottom of the app, its as if its zoomed in to the center of the app (only graph is visible)…
even if i close/re-open the app its the same
is there a shortcut key to get it out of this?
(only happened since 2.0)
hi, thanks indeed i can drag it down but three is no top bar… i then needed to drag it to the left then i could get the top bar back.
(running 3 displays so I do know about window sizing etc… never seen a program behave this way)
cheers for the tip though! all sorted
Hi… as for glassware… it runs in the notification area… When I click it… it should only open as a window (or full screen) on one of my displays…
I don’t think it supports true multi screen in the way you mention (and I wouldn’t need that)
I just expect that when I click the icon to maximise it, I can easily minimise or close it again… This odd bug seems to make it zoom in so that only part of the graph is visible on one screen
@krevvy Sorry for the problem. Our next update will solve this.
No worries! Thankyou
Garry
It’s fixed! https://www.glasswire.com/download/
Yep thanks!! All good at the update
hi, just had this again on my surface pro 4 today
(updated to *.80 a few days ago)
again i needed to drag the box/resize to see the toolbar…
Not seen the behavior again on my main desktop PC
Garry
Does the beta help?
