Hello everyone!
I’m looking to set up GlassWire on both a Windows 10 laptop and an Android tablet. Is it possible to use a single account for both devices, or should I create two separate accounts and somehow link them to monitor the Wi-Fi network activity of both gadgets on the laptop?
I will be grateful for your help!
Hi @Liane,
Licenses for GlassWire for Windows and GlassWire for Android are not compatible.
Unfortunately Google requires that we use the Google Play API for sales, therefore, our desktop app and our Android apps use completely different systems and can not be linked.
Sorry for any inconvenience.
Katie
Then I’ll install it on my tablet for now.
Thank you for your reply!
I have one more question if you don’t mind. I’ve just read that GlassWire can help identify potential security issues related to network activity. Can you please tell me if it can replace the antivirus on my tablet?
It won’t do it on your tablet but it will on your PC. You can only monitor the amount of traffic you are using on your tablet. Hope that helps. ![]()
Thank you, you helped me a lot!
@Liane
AV on your laptop is essential.
You can use Microsoft’s AV software (installed as standard) or a third-party software.
