Glasswire Things Monitor
I am a new Glasswire Basic user and still finding my way around.
My network set up is Wireless Broadband via a router. Connected to the network permanently are laptop (on which I am typing this), newtork WiFi printer and Sonos sound system.
Under Settings > Security > Things Monitor, I am told that Glasswire will report all devices joining or leaving the network. I have checked the appropriate boxes but when devices such as mobile phone and/or tablet are connected to the WiFi, Glasswire does not report this.
Am I doing something wrong?
Thanks in advance,
John
@John
What do your settings look like? There is one option to show only ā€œNewā€ unknown devices that join. That’s the setting I use because the constant coming and going of devices can become annoying.
Perhaps you have that option chosen?
If you go to the ā€œThingsā€ tab and press ā€œScanā€ do you see your devices? Also if you go to our general settings how often are your Things scanned for? There is also a Things related option under our general settings.
Thanks for your quick response Ken,
You have solved my problem.
In Settings > General > ā€œThings interval Scanā€ was set to 30 minutes so I changed it to 5 minutes. Basically, I was impatient! I expected devices which join or leave the network to show up very quickly.
I also didn’t realise that I can initiate a scan of ā€œthingsā€ at any time using the ā€œThingsā€ tab.
All devices are visible in the ā€œThingsā€ tab and the ā€œAlertsā€ section notifies me of devices joining or leaving. At the moment I have Settings > Security > Things monitor set to report all devices joining or leaving the network but once I am more familiar with Glasswire I will change that so only new, unknown devices are reported.
Thanks so much for your help.
Regards,
John
I’m just trying to figure out what this is! Of the top 5 search results, there is this, a notice that a scan is taking 24 hours, one talking about the Internet of things (toasters, fridges, speakers, thermostats, etc), and a few totally unrelated.
Of note, the OP has the free version? ā€˜basic’ user…
under the general tab ā€œThings scanā€ interval is unchecked. – makes no mention of needing the paid version
under security, ā€œthings monitorā€ is listed as a buy option.
perhaps its not working because John has the basic vs paid version?
I’m not sure that I understand your post Julie.
In my previous post I mentioned that everything was working fine. The problem I had was remedied by changing the Settings > General > Things interval scan to 5 minutes instead of the default 30 minutes.
The basic version is not free if you want to use Glasswire for a year or more. It becomes a subscription service after 7 days (I think it’s 7 days).
I’m not sure what you are running when you say that a scan is taking 24 hours. To my knowledge, there’s no scan in Glasswire that would take 24 hours.
Regards,
John
