Glasswire UI Randomly Crashing
Occasionally after interacting with the UI the client session will randomly close with no indication that it has done so until i go looking for the UI.
It is a 2 day old install on a fresh Windows 11 pro install, all drivers and the OS are up to date as far as i can see.
I have also experienced this once or twice within the past week. I thought it was Malware but event log just shows Glasswire closed and gave no error codes.
What version are you both using?
If it is the latest Version 3.9.1102
You could always uninstall it and try Version 3.8.1061
@GlassWare this sounds similar to issues I was experiencing with the previous few version where we had to wait months for the fix.
Hi, yes and we are still waiting for issues to be fixed with the 64Bit Version
Bizarre that given their track record they didn’t release this major architecture change as a beta first. As a long term user it was obvious to me that this wasn’t going to be a smooth transition.
