Glasswire unistallation failed
I wanted to install glassware again after my HDD with glassware installed Died, but it says that the uninstallation failed, and I do not know what to do.
Can somebody help, please
Did you recover the drive and get it working again?
Usually when I lose a drive, I do a clean install on a new drive.
I am reading that you want to uninstall/remove the GlassWire program from ?where?
no i want to install it and the drive is dead completely gone.
when i download the intlator end executed it will tell me uninstallation failed
If the drive in question, ā€˜died’, you will not be able to do anything with it other than take a 12 lbs sledge hammer to it to prevent any personal/private data from possibly being taken off of it.
Not sure why you want to uninstall a program from a ā€˜dead’ drive.
I don’t want to uninstall it I want to install it but when I try the app tells me ā€œthe uninstallation failedā€ and the only option is to exit. I want to install it again and I do not know why I can’t
You will have to use a new drive to install Glasswire because your present drive is failing. It will not install on a failing drive. :grinning:
If GlassWire uninstallation failed, try closing all related processes in Task Manager before uninstalling. Use the Control Panel or a third-party uninstaller tool. If the issue persists, reboot your system and attempt the uninstallation again.
I want to INSTALL IT but when I click instal it starts to instal and after like 5 seconds it tells me uninstallation failed
It’s a two-month-old SSD on which everything else works. Sure the drive is failing
Sounds like the installer is trying to remove the old installation from the old drive, before installing again. You will have to clear out the references Windows has to this old install. This can be done manually or by using an uninstaller utility.
