Hi, I have 2 account on my computer (Windows 11)
1 for me
1 for my children
On my account no problem, Glasswire is OK.
But it does not auto-start with the account of my son (not an admin account), and if I stat manually the parameters are the same of my account…
Any idea to have different parameters on different account, and any idea to auto start Glasswire on the account of my son ?
Many thanks for you help
Hi meepmeep864
Windows firewall is the same across all accounts in it workings.
GW uses the Windows firewall so that’s why you get the same situation.
You can create different firewall profiles in GlassWire Protect tab.
Though this is not the same as user windows accounts.
I’m not in front on my PC to check, but I think GlassWire uses the Run registry to start.
So it would be possible to add the entries on your son’s account to make GlassWire auto start. However, as GW said, the application monitoring and firewall settings are held in a single database and so will be common to all users.
