What is needed to establish remote monitoring of GlassWire?
You can use GlassWire to monitor remote servers or other computers that you control.
- You must run GlassWire on your local monitoring PC and on every remote PC or server that you want to monitor.
- A paid version (
) of GlassWire is needed if you want to monitor more than one computer at a time. In the free edition (
), you can change the IP address you are monitoring as often as you like. See the topic How to decide which edition of GlassWire I need for more help
A Windows Administrator password
Remote monitoring is turned off by default and can only be turned on with your administrator password. Also, GlassWire alerts you if you receive a remote GlassWire connection.
Two computers with GlassWire installed
Remote monitoring of GlassWire requires at least two computers:
- The monitored server also called the remote server: a computer running GlassWire that will provide the GlassWire data to the monitoring computer.
- The monitoring client: a computer running GlassWire to display the GlassWire data from the remote server.
If GlassWire is not installed on either of the computers, see How to install GlassWire.
Both computers able to connect across the network
Both computers need to be able to connect to each other over the network. If you cannot see the other computer then you might have to make it visible by changing settings on your router.
GlassWire connects using two numbers:
The IP address of each computer.
If you do not know the IP address of your computer then see How to find the IP address of your computer. -
The port number that the connection will use.
You only need to know this if you don’t use GlassWire’s default port. If it is changed then it is called a custom port.
Can you see the other computer on your network? See How to use the IP address to connect to a device.
If you cannot see the other computer then they may be on different subnets (sub-networks) and you will have to change the settings at the router.
Port forwarding to connect between different networks
If your computers are on different networks and you want to communicate across the Internet then the built in security at the routers should prevent this happening. You can enable communication using port forwarding which means you open a port so remote computers on other networks can access that port.
You will need to forward the traffic from the router’s public IP address to the computer’s IP address, where GlassWire is running. Refer to your router documentation for
- How to configure port forwarding.
- How to accept incoming connections on the router firewall.
If you have no router documentation then try a web search. Search for your router name or model and “port forward”. It is usually best to use the router maker’s website first.
Another option instead of port forwarding is to use a third-party service like Ngrok or Hamachi. Please note Ngrok or Hamachi may not be recommended for your type of secure network, so if you’re considering them in an business environment please discuss using those products with your local IT professional before trying them.
Setup remote monitoring
Setup the monitored computer, the remote server, to allow access
The server settings to allow a connection from a remote client are GlassWire Menu | Settings | Server | Remote Access
Glasswire calls this remoting in which is connecting to the current computer from another computer…
- Select “Unlock”
- The Windows UAC dialog appears and asks you `Do you want to allow this app to make changed to your device?
- Select
Yesto make the changes or selectNoto abandon this process. - Check the
Allow Remote Access by passwordcheckbox because a password is required. - Select the
Change Password...button so theEnter passworddialog window appears. - Enter your chosen password into the
Passwordtext box. - Check that the password strength is strong or very strong. If not use a better password.
Retype Passwordtext box. - Select the `OK button to save the password.
For extra security we recommend you only allow access from your IP address if it is a static IP address that doesn’t change often:
- Check the
Allow Access only from IPcheckbox
- Type the IP address for the client computer into the textbox that says
Type IP Address Here - Select the
Addbutton to add the IP address. - Repeat the previous two steps to add more IP addresses.
- Select the `OK button to save the IP address list.
You can check that Remote Access State is Allowed at GlassWire Menu | Settings | Server | General
Setup the monitoring computer, the client, to gain access by remoting out
The client settings to connect to a remote server are at GlassWire Menu | Settings | Client | Remote Server
GlassWire calls this remoting out which is connecting out of your current computer and into the remote computer.
- Select the
Add New Serverbutton
- Enter a name to identify the remote server on this client in the `Name’ field.
- Enter the servers IP address
- Enter the server password that was input to GlassWire Menu | Settings | Server | Remote Access on the other computer.
- Check the
Enable connectioncheckbox - You can add more than one server if you are using a paid edition (
) - Select
OKto save the changes.
Once you are connected the remote server’s network activity will appear in a tab onn the left side of the GlassWire main window. Click on the tab to see the main tabs (Graph, Firewall, Usage, Network and Alerts) as if you were using GlassWire on the remote computer.
How to improve this topic
This is a wiki post, like all the other #how-to topics, so feel free to improve the content. Just leave a reply explaining what you’ve done and why it makes sense to do it that way.
it so we can see what is most helpful to people.
