How to Enable Logging and Send GlassWire Logs
If you’re experiencing an issue with GlassWire, enabling logging can help us diagnose the problem more quickly. Just follow the steps below:
1. Open the GlassWire folder
  1. Press Windows key + R on your keyboard
  2. In the Run box, type:
    C:\ProgramData\GlassWire\service-full
  3. Press Enter
2. Enable logging
  1. In the folder that opens, locate the file named glasswire
  2. Right-click the file
  3. Select Open with → Notepad
  4. If prompted, choose Run as administrator.
    Note: If you do not see this option, click on the Windows Start button and search for Notepad, then select the option “Run as administrator”. Once Notepad launches, open C:\ProgramData\glasswire\service-full\glasswire.conf.
  5. In the file, find this line:
    LogEnabled = false
  6. Change it to:
    LogEnabled = true
  7. Click File → Save, then close Notepad
3. Restart the GlassWire service
  1. Press Windows key + R again
  2. Type:
    services.msc
  3. Press Enter
  4. In the list, find GlassWire Control Service
  5. Right-click it and choose:
  • Restart (recommended), or
  • Start (if it’s not running)
4. Reproduce the issue
Use GlassWire as you normally would until the issue happens again.
This ensures the logs capture the problem.
5. Send us the log files
  1. Open this folder:
    C:\ProgramData\GlassWire\service-full\log
  2. Select all files inside the log folder
  3. Send them to: help@glasswire.com
    → Please also include any relevant forum link related to your issue so we have full context.
:light_bulb: Tip
The more details you can share about what happened (what you were doing, what you expected vs what occurred), the faster we can help.
