Hello friends, My system showing msvcr100.dll missing error and I want to fix these missing dll error but i can’t find a right solution.
Please suggest the right way to fix this.
Hi ray_22
Try this fix, There are other fixes but try this first.
Download the Microsoft Visual C++ 2010 Service Pack 1 Redistributable Package MFC Security Update and run it. This will replace/restore the msvcr100.dll with the most recent copy provided by Microsoft.
There are a few download options from Microsoft for this update, based on the version of Windows you have installed—x86 (32-bit) or x64 (64-bit). Check out our advice on how to determine if you’re running a 32-bit or 64-bit version of Windows if you’re not sure what to choose.
