so i blocked all connections for Skype by accident and know Skype has stopped (after unblocking it) working ive tried re-installing both Skype and glass wire thx for any help
Uninstall GlassWire, then go to your “ProgramData” folder and delete the “GlassWire” folder, then reboot. Is Skype still blocked after the reboot? If so go to your Windows Firewall control panel and click “restore defaults” on the right side. Next please reboot again, then see if Skype is working.
If Skype still isn’t working are you using a third party firewall besides GlassWire? Or maybe Skype is down? Or maybe Skype should be uninstalled/reinstalled.
