Glasswire staff
you may remember the below picture, You suggested a re-install with clean .Db etc
Well i’ve been running out problem since then, over a month +. However i have found a scenario were this happens
So i currently have 2 internet connection
- my pc is connected to the first, It has gone down so of course Windows goes into Limiited connectivity mode.
- when this happens after some time the idle service goes haywire & creates multiople processes (250+ in fact)
- changing my Ip configuration to my second gateway & restoring the net connection, rectifies the idle process issue,
so you should be able to reproduce this in your lab by going into a “limited connectivity” state, eg editing your Gateway or Ip settings so you cannot get online.
in affect somthing about losing a Internet connection confuses your software.
