Hi. I’m using Glasswire on my Pixel2XL running Android Pie. There is always a difference in the mobile data usage reported by Glasswire and the data usage reported by the device. Is there a reason for this difference?
Thanks
I have a Pixel phone also.
Is the data usage under-reported by GlassWire or do you feel it’s over-reported?
It’s under-reported. Been using Glasswire for 3 months now.
Could you set GlassWire as un-optimized and see if that helps?
- Go to Settings > Apps > Your app > Advanced > Battery > Battery optimization
- Change view to All apps
- Search for your app
- Choose Not optimized
If our app is killed it will under report the data usage. Meanwhile we’ll have an update this summer that will no longer require this change.
