It might be valuable to include quick links in the Apps portion of usage for IPs and domains to some sites. I usually look up IP on robtex.com, and check URLs/domains with virustotal.com or urlvoid.com.
What do you think?
Matt
What do you think?
Matt
Matt,
You are reading our minds. We also wanted this during testing but we’re trying to figure out the best way to implement it so it isn’t ugly or annoying.
Last time I emailed the dude who does robtex, he said he doesn’t have an API currently; but maybe you guys could work together to figure something out. http://cy.linkedin.com/in/robtex or info@robtex.com
I will check it out, thanks!
