Can you put glass wire on kindle fire 10 2017? Can you used the same code?
I don’t think GlassWire is compatible with the Kindle.
From what I can see, it looks Kindle Fire will run many Android apps. Maybe Glasswire for Android?
Another user apparently got it working:
Thanks for advices guys!
I don’t think you can use the same code
