Legacy licences
Hello, with both the latest versions all my pro elite codes now are basic?
But when i check the features looks like it should be, is this an overlook cosmetic only problem ?
Thanks
Konstantinos
Normal as I have two Elite Legacy Licenses but you can’t use there online console, but all is fine!
Thanks for bringing this up. Could you share where exactly you’re seeing this? A screenshot would also help us better understand what you’re referring to.
I just installed the latest version of Glasswire with my Basic Legacy version and retain all the full features as I’ve done for many years. Thanks for fixing all the problems with the 880 version as I was running an older version after all the issues, and am glad to be able to keep using Glasswire after 10+ years!
I’m really happy to hear that you’re having a better experience with the latest version. Please keep all the feedback coming and thank you for being a dedicated customer!
