I’ve set up remove connection on one of my many PCs, PC that I use as a file server - I’ve set it so only one IP is allowed to remote into GlassWire
so, it’s pretty annoying to see the notification that the trusted IP logged in
can we have a option to either:
log but don’t notify GlassWire client connection from IP Xxx.xXx.xxX.xxx
Go to GlassWire settings, then the security tab and click “remote glasswire connections” then uncheck “notify me of remote GlassWire connections”. Does that fix it?
The reason we added this as on on default is because it would be scary if some remote PC is monitoring your GlassWire stats. So we wanted users to know that it’s happening, but you can disable these alerts easily.
