Hi
I use a data plane with 2 traffic, 36G in day time and 120G in night time, Night time start 2:00 to 7:00.
I don’t want these two mixes together.
I want more than one profile.
I use two sim cards in one device and the second sim has 450G data only from 1:00 am to 11:00 am, Now they three.
How can I manage them?
I have good news. We are working on a MAJOR Android update. It’s a complete redesign of the app both visually, and with a completely new backend.
This new version works with dual sim devices and I have been testing it myself (although I currently only have a single sim device).
We hope to have the update out in the next month or so. I think the feature will go live with the release unless we end up finding some unexpected major technical issue.
I use dual SIMs for data on Android 9 if you want a tester.
If you go to our Google Play official page I believe there is a “Beta” link, and you can join our beta. If you’re in that group you’ll get access to the new version before other people @Remah. Thanks for your offer and we’d appreciate your feedback.
Currently though we have no beta out yet.
@Ken_GlassWire
Any update for this feature? I really really need this.
We’re investigating how to add a feature like this while keeping our data alerts feature understandable. It’s a bit tricky to build a user interface for this idea. Thanks for your patience.
Yes, this is mostly a tracking restriction for Android. If the programmed doesn’t enable per-sim rule settings, dual sim + time based plans don’t split cleanly.
Data will continue to be messed up until that is constructed.To be honest, this can only be truly fixed with a rule engine upgrade.
