im using a external encrypted SSD (always mounted on the same drive letter). From there i start portable apps from portableapps.com. Every time i restart windows and start a portable app(any network connecting app) again, glaswire ask me again to allow the connection. In the firewall and usage tab the portable app has multiple entries.
I think this may be expected behavior since each time the portable application is different than the previous one. You can mouse over the app name and click the âXâ next to it to delete it manually, or it will automatically move to âInactive appâ in awhile.
I donât have much experience with portable apps. Let me ask the dev team and see if they have some ideas/comments. Could you give us some examples of several portable apps that do this for our testing? Thanks.
Ok, i did some more testing, it is the combination of portable Apps and encrypted! portable Samsung SSD. When i deactivate the software encryption at the Samsung SSD tool then there is no problem.
With encryption enabled you can test it with every portable App, for example Firefox Portable portableapps.com/apps/internet/firefox_portable
I know it is a very special case, but maybe the developers can look into it, because i really want to use a encrypted external ssd without the multiple entries in the firewall.
Warning: Self-Encrypting Hard Drives and Encrypted Hard Drives for Windows are not the same type of device. Encrypted Hard Drives for Windows require compliance for specific TCG protocols as well as IEEE 1667 compliance; Self-Encrypting Hard Drives do not have these requirements. It is mportant to confirm the device type is an Encrypted Hard Drive for Windows when planning for deployment.
Unfortunately i cant use BitLocker because i only have windows home. But i tried the software encryption software VeraCrypt and this is working without glaswire multiple entry problems.
It is still strange for me that i have multiple entries with the hardware encryption of the external Samsung T1 SSD, but for now its fine with the software encryption. Maybe when a developer get in touch with a Samsung T1 SSD he can explain it to me
have to step in here, I think the encryption is secondary for this problem, the portable apps from portableapps.com and every other self contained portable exe (not installed in windows, only started) is not working with glasswire, that kinda sucks. perhaps I need a new topicâŚ
Everything works fine until I restart windows, then the connection is blocked and I have to remove the entries of portable apps. Once the âDo you allow it to connect?â dialogue is confirmed it will work just fine again.
How to reproduce the problem on any Windows PC:
Set Glasswire to âAsk to connectâ
Download a portable app, e.g. âKittyâ
Try to connect to some random IP, it doesnât matter if that IP really exists
Confirm that this app can connect to the internet
Restart PC
At this point Glasswire will block the portable app and wonât ask if it can connect again
Delete the portable app from the Glasswire whitelist
Confirm (again) that the app can connect to the internet
The app will work until you restart your PC again
Its really annoying, other firewalls are not causing this problem. Iâm not sure why Glasswire behaves like this because the binary name and file hash did not change after a restart.
Energy saving mode or a restart of the portable app wonât cause any problem.
Iâm able to reproduce this problem on various pc and laptop configurations.
Only discovered this in the last couple of days as I donât usually run applications from a USB device. On this occasion, I was just doing some very long overdue maintenance! I donât think the issue is particular to PortableApps[dot]com i.e. it affects any software being run from a USB device. My initial workaround was to temporarily toggle From âAsk To Connectâ to âClick To Blockâ before running the USB app (e.g. PortableApps[dot]com Updater) but the âdelete from whitelistâ is a more secure workaround so thanks for that.
