Hi, I have my Firewall setting set to Ask to Connect. The program I’m running asks to connect I click on Allow but it still blocks part of the connection.
Is there a way to whitelist an application? Is there a way to get it to work with asks to connect? As I need the other new programs to ask me to connect… All other programs so far work with asks to connect but not this one.
I did try removing the application from the firewall list then restarting the app in question and allowing it but its still blocking it when on ask to connect.
If you look at the network activity when you’re using that app (when in “click to block”), is the data going through the actual app or something like Edge/IE instead? Sometimes some Windows apps are just a part of Edge/IE, so the data is actually going through that browser. To solve the issue you should unblock Edge/IE.
