Hi
Been having this problem for a while now.
Not sure if it is related to a GW update or 24H2 update as both where done around same time but suddenly noticed nothing is showing in Network Scanner even though everything is working as normal.
Internet connection and speeds are consistent, stable, computer is working fine and is operating without any issues (stable and consistent), network traffic is as expected but this issue is here.
I have tried a complete reinstall (including resetting windows firewall after removing all traces of GW, including registry entries) and rebooting then performing a clean install.
I have also tried Legacy Drivers and still the same issue.
Can anyone provide a possible solution for this please?
Thank you
Hi PsYAuM
Might be best to send email to
help@glasswire.com
You could just copy your issue above and send it to them.
facing the same issue after the 24H2 update, any solution ?
I see the same thing in my system during the small amount of time I am able to keep Glasswire open. Because it keeps crashing over and over.
