Network scanner was working ok few days and now keeps scanning and nothing happens, any help?
windows 11
windows 11
any help Glasswire team?
Check your internet connection, if your connected check your settings. Check to see if your Glasswire Firewall is turned on. Check your subscription, has it run out. Hope that helps. PS: Make sure you have the latest version. ![]()
