GlassWire stopped logging anything after few days of using it. (without rebooting)
Graph/traffic for last 24hours is completely empty.
Windows 8.1 64bit
Windows 8.1 64bit
Do you use Bittorrent? Can you uninstall, then go to your “ProgramData” folder and delete the “GlassWire” folder (unfortunately this will delete your data) then reinstall?
yes I use utorrent
reinstalling glass wire helped me to fix this problem
it took me few days to realize it stopped working
This Bittorrent problem will be fixed very soon. We are finishing up an update that solves it. Thanks for your patience. If you’d like to join our alpha list please https://www.glasswire.com/contact/ contact us and put “test group” in the subject.
