Hello, I easily installed the latest version of this program on Windows 10 Pro, but it gives an installation error on Windows 10 LTSC. Does anyone know a solution? I wanted to install it as a portable version, but I couldn’t add its drive to make the program work properly. please help me i need to help
Hi Ghost87
Glasswire may or many not support LTSC. You would have to test things your own way.
Uninstall reboot then try clean install etc.
Glasswire is not meant to be a portable App, so when you were trying to get it to run that way, then maybe this is why you get instillation error.
Yep, GlassWire has a control service which requires system installation. That is unlikely to work as a portable app.
please a fix for new update glass wire ![]()
Hi,
I am just another user like yourself. You would have to reach out to the GW team.
I don’t think they support 10 LTSC as it is for Enterprise use only
The dangers of having a rather similar username.
