Glasswire should remember the GUI settings that an user has chosen.
For example All/Apps/Traffic/Publishers filter always defaults to All.
I - for example - always use Apps filter. I need to manually select it every time the app starts.
The app should simply remember the GUI state before closing.
I am seeing this for both graph and usage tab - always defaults to All on every app start.
Thanks for your feedback. I will share with our team. We may have some limitations with the API we use that could cause us to be unable to hold the same view on app restart but I’m not sure.
