Using version 1.2.121 everything worked perfectly well.
After a clean (incl. reset windows firewall) installation of version 2.0.78 the mode Firewall “Ask To Connect” does not work with ibVPN - it’s not possible to connect to the Internet - Resolving host…
It’s for example not possible to connect to a website - tries to resolve host.
Thanks for your response! Both v. 1.2.121 and v 2.0.78 contains a file glasswire.conf. The conf-file in both versions contains some lines - one of them:
hostname_enable_nslookup = true
v. 1.2.121 works with “true” but not v 2.0.78. I tried to change to “false” in v 2.0.78 as you suggested, but no success. I’ll roll back to v. 1.2.121 waiting for a solution.
I try to summarize:
In version 1 it works having the line “hostname_enable_nslookup = true” in the config file
In version 2 it does not work having the line “hostname_enable_nslookup = true” in the config file
In version 2 it does not work having the line “hostname_enable_nslookup = false” in the config file
By not work I mean I can not connect to the internet in Firewall mode “Ask To Connect” using ibVPN.
Is it blocked by the Firewall or is it DNS probem …? ibVPN connection is established using “Click to block” but not “Ask To Connect”.
Awaiting a response on the ticket I found that there is a 24 Hours Free Trial ( https://www.ibvpn.com/billing/cart.php?a=view ). There is also a an app - ibVPN - for Android at Google Play Store.
Glasswire can offer one Standard package for Glasswire to fix the issues and test.
The request must come from ibVPN side, from management or Project Manager. You just need to open a ticket and request it. Maybe is a good idea to add this ticket number (#156607), so the support technician will know what has been have discussed.
