Hi All Bro
Im Change Windows And Install New Version (Update)
Photo Information And Screen From Error :
Windows : 7
64bit
Ram : 4Gb
VGA : 2
Labtop : Hp
https://cdn.anonfiles. com/ 1415819490433.png
Please Help Me
Hi All Bro
Windows : 7
64bit
Ram : 4Gb
VGA : 2
Labtop : Hp
Please Help Me
Please try completely uninstalling GlassWire, rebooting, then reinstalling and let me know if that helps. Sorry for the problem!
Tnx Bro For Rep But :
I have not installed this software in new windows
This happened to a friend of mine that still did not solve the problem
Can you help me?
Please ask your friend to uninstall GlassWire, reboot, then reinstall. I think that should solve the problem.
The problem still is not solved
looks to me like a problem with Windows installer…or some corrupt installer…what installer does GW use anyway?
For Me Error Installer
if thats the case you may need to do is run a repair on your windows version…using the windows cd/dvd…or if its a custom build, then a windows recovery cd/dvd…
Brother
Im Download New Version Windows 7 64Bit And Install From Flash Memory And No Problem With Windows
Else had the same problem with Windows
Hi All
Problem Resolved <3
im Change the Location From Regeon And Language Option To United State And Good Work :x
Please Fix The Bug To Region to Iran :x
Tnx +Rep
