The reason I suspect is because I regularly have a torrent client running with 10K+ outgoing connections causing the stack buffer overrun. To Glasswire’s credit, this has happened with other firewall software.
I’ve looked through similar threads and I’m not sure what the solution is, would adding the (suspected) problem application to incognito solve it?
PROCESS_NAME: GWCtlSrv.exe
ERROR_CODE: (NTSTATUS) 0xc0000409 - The system detected an overrun of a stack-based buffer in this application.
