On my s8 even with the fire enabled it fails to block any apps, netgaurd doesn’t have this problem and function correctly but sometimes just stops everything thus me looking to switch.
The app looks great but I really do need the firewall to work any ideas?
ok so ads have stopped showing in es file manager which makes me believe that it is intermittently working which is great. Still shows network actively even on blocked apps? is this normal behaviour ?
@Vorticalbox
This is a known issue with Samsung phones. To solve it please update your phone Android OS version.
https://www.glasswire.com/android-help/#common-problems-n-solutions
Also please check the tips above.
