Hi,
I am using a firewall at home with 2 WAN ports.
One is connected to my default FTTH provider (no fixed IP), and the other is connected to a LTE modem which is used in failover mode if the first connection is going down.
While my FTTH connection has a flat data rate, my LTE connection does not.
I am searching for a tool (preferred glasswire) that is showing me on my Windows 10 PC which connection is used atm.
So if my external IP is belonging to my FTTH provider it should show this, or in the other case show that the LTE connection is used. Can I do/see this somehow?
Kind regards
