and i have an speed of 20/1 mbps soooo it isn’t possible for me to even upload all that data.
and
im monitoring traffic flow through my router and windows task manager and it isn’t showing this data.
I have 2 partitions on my hard drive
one for os one for storage
i have a a File History folder which is shared as a network drive. on my pc. ( only way to have file history on the same drive as windows.) so my when my PC copies files from my C partition to my F partiton, (both of which are on the same hdd therefor same computer) , something is registering it as over the network, which causes glasswire to display it, even tho nothing left my computer.
I’ll report this to our dev team and see if they have some ideas how this is possible. I have never seen this reported before. Are you sure it’s actually just data between partitions or could it be a printer or some other shared network device that’s available locally? If we knew the hosts it might help us figure this out, perhaps you could email us some screenshots to help us investigate and fix it? https://www.glasswire.com/contact/
Lots of our users use different hard drives and we have never seen this reported before.
i don’t think it’s a fix you can do, i think it’s a windows thing. When i get home, i can show you pics of how i set up my file history. My guesss even tho folder is on the same computer, it is mapped as a network drive which smoeone makes windows think its network realted. in my pic you can see its equal upload as equal download.
Oh, I see. Yes, if it’s mapped as a network drive then I think GlassWire’s behavior is technically correct and there isn’t anything we can do to solve that.
That is a link-local address so I’m surprised that Glasswire does not count it as Local. I thought that either the “fe80” prefix or subnet masking would allow you to determine that this on a local subnet.
@Arthur_Vardevanyan Could you email us https://www.glasswire.com/contact/ and make the subject “forum false system.exe”? Our dev team made a custom version of GlassWire to test so we can fix this problem for you.
