Dear all
please I have issue that my wifi network is very very slow can I use the GlassWire to monitor the network and see how is using the utilization
You can use GlassWire to see if your PC is causing the slowdown, then block any data wasting apps.
You can also get a list of all the devices on your network.
Thank you Mr. Ken for your replay
that’s mean I can monitor who is consume the bandwidth in my network and which pc
Yes, that’s correct.
In many cases PCs are responsible for overages. Once you figure out the PC that is responsible go to our Usage tab to see what apps are using up all your data, then block them.
