Can GlassWire Detect traffic related to the Sunburst Cyber Hack yet? This would make it a very helpful Tool!
TIA!
TIA!
Thanks for your feedback. I believe if you are using their Orion tools that you should read the instructions from Microsoft on what you should do exactly. I believe at this time they are suggesting you disable that system completely until you can update it.
It seems like it’s a bit of an unusual situation that hopefully won’t happen again (in the same exact way that’s detectable) so I am not sure if it’s worth adding detection for this.
Some more info about this from Microsoft: Analyzing Solorigate, the compromised DLL file that started a sophisticated cyberattack, and how Microsoft Defender helps protect customers - Microsoft Security
