Hi Guys,
All my Traffic Monitor data is no longer showing any information, I am informed “No Current Data Usage. Check other time periods” It just stopped, was OK earlier this morning. I have tried restarting it and no joy. Any ideas?
Check your Ethernet cable and/or your Wi-Fi. See if your ISP Provider is up and running. Hope that helps. ![]()
Hi SirBasher
Maybe first try uninstall and reinstall. Remember to reboot after doing both.
Note, If that does not work, you could try again and select the option
Clean Install (Clear Data & Settings)
But remember that will wipe any Data and settings you had in the past, you would be starting from scratch.
Restart sorted it, thanks ![]()
