Turn Off Norton 360 for Gamers
“I’m using Norton 360 for Gamers and I need to temporarily turn off or disable its antivirus protection, but I can’t find the option. How do I properly turn it off without uninstalling it.
The Norton 360 program can provide the utmost protection for your gaming PC. But, without the proper settings and filters you may face some interruptions during your gaming session.
Facing this problem can be frustrating if the pop-ups appear frequently. As a result, it is good to turn off the Norton 360 program to avoid facing any issues. Here you will learn everything to do that properly. So, keep reading until the end!
Before your move with the steps to turn off the Norton 360 program on your device here are some things to keep in mind to avoid the mistakes.
  • Using the wrong path and disabling the other feature.
  • Clicking on the wrong disable button.
  • Some do not close the app after turning off the security feature.
  • Selecting the wrong duration, and many others.
In addition, here are the quick steps you need to follow if you want to easily turn off the Norton 360 security program on your device.
  • Initially, choose the Show hidden icons arrow on the bottom-right of your Windows taskbar.
  • Then, you should right-click on the Norton icon, then choose the Disable Auto-Protect option.
  • After that, choose the More Options dropdown and choose how long you want protection disabled.
  • Now, confirm if the Norton 360 has been disabled on your device or not.
Thank You…
Probably better to post this in a Norton forum.
Best Norton thing you can do is run the Norton Uninstall Utility.
