I have your free version and am trying to use it to understand data usage so I can see where I am using it. When I look at the usage tab under the monthly time frame I see total usage of 12.2GB but when I try to see where I am using that data it shows under the apps column that 8.4GB was used for host process for windows services. What does that mean?
I use Think or Swim which is a stock trading program which streams data and it shows I used 860.2MB which doesn’t seem like enough. Could it be that the data is coming in at another level so I don’t see it. I am not a geek so I may not be explaining it correctly.
Another question is I use Windows 10 and it’s usage shows about 4GB for the month and glasswire shows about 12GB so I seem to have that same 8 that I am confused about.
Thanks,
Mark
