When I change an Option on the Usage tab, those options always reset to the default when I Quit Glasswire and restart. I would either like to have those options stick and Glasswire is restarted with the same options I had earlier set, or give us a way to request that the options are sticky.
For example, I’m currently most concerned with my overall network traffic usage through my gateway. Internal network traffic is not an issue. I always must reset the Options to select “External” under “Internal & External”. Minor, but a royal pain as I must do this for every system that I am monitoring.
