Just a small thing. I read quite a lot about that GlassWire can’t read out other devices network usage. I think there could be a quick workaround.
It could be pretty simple. What if you configure the Wifi of devices that it should connect to an host PC. From host pc to wifi router and to the internet. Same way back.
General all data need to go through the host machine. This way it should know who is who and even see usage and current usage of all devices which are linked to the host PC. This could be done with proxy.
GlasWire set up a virtual proxy server which other devices can connect to in the wifi settings.
This way literally any devices can connect to and can be displayed. It would be a quite good thing because you don’t have to install it on every devices (if it avaible tho) to have a good view of your network usage.
This will increase the ping time but generally that is quite good idea. Maybe you found a another way.
I’m haven’t purchased GlasWire jet because of this missing feature. It’s just a small thing. Also i’m not a programmer or sort of. I understand most code but coding myself is impossible to me.
This just speculation!
