I have a Application which is not Blocked.
In some cases the Application opens an connection to an WEB API which is blocked by glasswire. How can i unblock this. I set my policy to “Ask to block” but i dont get any notification.
This happens on a freshly installed glasswire in the newest version.
Hi @Keldor,
Can you confirm which setting your firewall is on? There is a Click to Block mode or Ask to Connect.
It sounds like yours may be on Ask to Connect?
Thanks,
Katie
Yeah, the firewall is on. Ask to Connect is my prefered Method of seeing connections.
I Solved the case by checking the processes again. The Application spawned a subprocess of chromium which i did or got blocked by glasswire. All good now. Thanks for the help.
