For the forth time I have had to reregister Glasswire. What is going on with it?
Sorry for the issue. Do you use any software like CCleaner? If so, can you white list the programdata/glasswire folder?
Another option…
Are you using a secondary firewall, or did you use one previously? Sometimes they can block GlassWire from its activation server. White list activate.glasswire.com if possible.
