When I work on the PBI Desktop app at some point, everything blocks and windows crashes with the blue screen and error code DPC_WATCHDOG_VIOLATION
This stops happening after I stop the Glasswire app and stop the services.
Found the solution from this link where the same has happened to another one as well.
https:// community.powerbi .com/t5/Issues/Windows-10-crashes-with-blue-screen-while-using-Power-BI-Desktop/idi-p/975581
If you go to our top left menu and choose “About”, what version of GlassWire do you have? Can you see if there are any updates for Power BI Desktop also?
I Have the latest PowerBI Version. I have tried The Latest PowerBI from the website and MS Store.
Also tried Many old versions of PowerBI as well. Tried with a fresh install on both my PC and Laptop. Had the same problem.
The problem only started around a few months ago. so I guess maybe the new glasswire version might be the issue. but I couldn’t find any download links for the older glasswire versions.
Is it important you keep your GlassWire data usage history? Usually crashes with GlassWire are due to a corruption of our database. A clean install may solve this.
Go to add/remove programs and uninstall GlassWire.
Reboot
Reinstall our latest version with “clean install” checked.
If that doesn’t solve it, do you see any .dmp files on your desktop? If not, then it may not be GlassWire crashing.
Sorry for the issue. The .dmp is actually generated by Windows itself, not GlassWire. If Windows is not generating a .dmp for GlassWire then it should not be GlassWire that’s crashing.
Where do you see the “watchdog violation” in relation to GlassWire? Could that software be incorrect?
