Blocking by IP rather than application
Hi, is it not possible to block particular IP addresses while leaving the program itself unblocked? I know this can be done in Windows Firewall, but having to manually edit every instance would be a real pain and would kind of defeat the purpose of using GlassWire…?
@j_mo
We are actively working on host blocking.
Hello Ken,
Any updates on this?
We are still actively working on host blocking and we’ll probably implement it in several stages. Thanks for checking in.
Any updates? I feel like this feature is a necessity for any firewall system as its essential for blacklisting bad hosts from hacking you through specific application backdoor vulnerabilities. Please roll out soon!
Since “actively working” on implementing IP Blocking feature, where we are at now? Without that feature, or Country Block, I don’t see a reason why I should purchase a license for the software. Thanx
@Mystagogue
Thanks for your feedback on blocking by IP address.
Any update on this ?
You guys are actively working on this for 6 years. It must be very hard to do…
Any update on this?
The team is really working hard… I guess
Strange this has not been implemented!
as GlassWire uses the Windows firewall API
I have instead gone into the windows firewall direct
and blocked a group of IP address in one rule.
