Glasswire can't connect to local server help
currently I’m not a GlassWire user but sometimes a firewall or a VPN (especially if the VPN killswitch is enabled) could block the communication between the service and the client. If I remember correctly it occurred to me a few years ago when I had installed GlassWire Free as a network monitor, in that case it was the firewall.
Try temporarily disabling Webroot and Zemana Antimalware to see if they’re blocking GlassWire. After uninstalling GlassWire, reboot your PC before reinstalling it. Avoid using third-party uninstallers. If the issue persists, contact GlassWire support with detailed logs.
