Actually, if you buy GW, at the end it will be cheaper for you:
GW is 1 time charge, meaning you only pay the firewall once, IN YOUR LIFE, no payments after a year, 2 years, or 3 years, its GW forever!!
so, even if you buy GW, you will save some money within the time. lets put an example:
—I DIDNT BOUGHT GW—
so, I will pay, 60$ EVERY YEAR for a kaspersky internet security. at the end of 5 years, I would’ve had paid around 300$ for the antivirus.
—i BOUGHT GW—
I bought GW and kaspersky antivirus. totally, I paid 88,95$. BUT since GW’s license is FOREVER, I will only need to buy kaspersky antivirus every year. so, at the end of 5 years, I would’ve paid around 248,75$.
CONCLUSION:
buying GW and using a simple antivirus like kaspersky antivirus is cheaper than buying kaspersky internet security every year.
in a bigger picture:
at the end of 10 years: +/- 100$ saved.
20: 200$
50: 500$
So, you are saving 10$ every year. its not that much, probably I would buy kaspersky internet security anyway, but if you like saving money, than buying GW is the best option, unless you found cheaper antivirus with firewall included.
also, you, unless you want to install GW to the hole family, as you probably are like me, a simple user of computers, that knows nothing about IT, than you would never need more than basic GW plan. and even if you buy Elite, at the end of some years, it will make you save money anyway.
but in one thing I have to be with you: spending 200$ in a second could be way too heavy for a lot of wallets xd.
maybe GW could think about implementing a way to make people able to pay for example, 33.16$ every month for 6 months, becouse I live in europe, dollar is not for me, but maybe 200$ are not for all the wallets…
(sorry for the massive amount of text)
